Old 11-07-2008, 01:23 PM #1
amt006 amt006 is offline
amt006 is on a distinguished road
lube suspension?
Ok guys don't flame me please. I have been looking all under my 2007 Sport 4WD 4runner for the grease points for the front suspension and can't find one Zirk fitting. The reason want to lube up the front end is I have a really nasty sounding creek when hit bumps while making really sharp turns. The only grease points I have found are the ones for the drive shaft.
Aaron
2007 v6 Sport 4wd
Toytec Ultimate 3" lift + Spidertrax 1.25 spacers
Cooper Discoverer STT LT265/70R17
WeatherTech FloorLiners & Side Window Deflectors
Aries Brush Guard with Hella 500 Driving Lights
amt006 is offline   Reply With QuoteReply With Quote
Old 11-07-2008, 02:14 PM #2
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Re: lube suspension?
Aaron
:awais: :chair: :cursin: Duh, what's wrong with you man?
KIDDING! You're correct, 6 fitting total for F & R driveshaft, no fittings on the front suspension. Cut the steering all the way, shut it off and look at the linkage. You'll see the contact point that is the "stop". A touch of grease there and then in the same place but other side and you should be good to go That's probably what's making your squeak.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 11-07-2008, 02:40 PM #3
I went out and took a look under my truck. I took a picture of my front end driver side circled where I just put some grease. Is this the right spot? If not can you please let me know where the right spot is. Under full turn the 2 areas I greased do not touch but I did see what looked to be wear marks.
Thank you,
Aaron
lube suspension?-pb070334web-jpg
2007 v6 Sport 4wd
Old 11-07-2008, 03:12 PM #4
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
I went out and took at look under the truck. Took a picture of my front end driver side. I circled where I just put some grease is this the right spot? If you can please let me know where the right spot is. under full turn the 2 areas I greased doesn't touch but I did see what looked like wear marks.
Thank you,
Aaron
You got it, 100% correct.
Old 11-07-2008, 03:17 PM #5
Ok now its time to make some really hard u turns with bumps to see it this stopped the creeking.. Thanks for the help...
Aaron
2007 v6 Sport 4wd
Old 11-07-2008, 04:26 PM #6
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
Originally posted by riverider
Makes me glad I bought a 2wd 4Runner.
I'm pretty sure yours is the same as the pic minus the CV shaft.
Old 11-07-2008, 10:50 PM #7
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
There are no grease certs anywhere in the driveline or front suspension on my 2wd 08 4Runner...
...Also no way of checking the transmission fluid on my 08 4Runner.
You're right about the driveline. I wasn't thinking about that... Sometimes I am not the sharpest tool in the shed.
I was thinking about the steering stops, I think your 2wd has the same setup that requires an occasional dab of grease.
You can check the fluid but it's a pain: http://www.toyota-4runner.org/showth...threadid=36489
Where to lube the sunroof and what lube to use G.I.G. 4th Gen T4Rs 11 04-17-2016 10:36 AM
Suspension Replacement ?'s FJ Cruiser I think.. MDVDuber Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-17-2010 02:05 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
?? Bull Bar - Winch w/ Stock XREAS Suspension damengr Off-Roading 2 08-16-2007 12:55 PM
Suspension woes (name that tune)!!! ('04 SR5 v6, 4wd) kujhawk80 Problems & Warranty Issues 10 12-21-2004 01:22 PM
