Tacoma suspension swap onto GX470, thoughts?
yotaman81
Hey there guys, been a lurker for some time, been doing a lot of reading on suspension upgrades and reading up on what will work and what won't work. I have an opportunity to get a set of fox shocks 2.0 with less than 5k miles for $600 with mostly highway driving according to the owner. The donor is from a 2016 Tacoma 4WD. I plan to do a mild 1-2 inch lift and mainly use it for my commute, light trails for fishing and camping trips but most of my drive will come from 90% commuting. My GX is stock, no plans to add any heavy gear or bumpers, just replacing the rear OEM shocks that are going out. I hear that the Tacoma suspension would bolt right up front of our chassis but that the rear would require a new eyelet bushing in order to have it bolt up. I understand that there are several configurations I can go; toytec ultimates, dobsons, bilstein and etc, but for the price and with some modifications, would this be a bad deal/idea? Thanks in advance
Ended up getting them, with around 5k, they're pretty much brand new and couldn't be more happier. Just need to replace the eyelet bushing in the rears then throw them on. Looking to get a 2 inch lift and level out. My rig, 06 Gx470 Sport, all stock. Future plans, 285/70-75/17 Falken AT3s and swap wheels for a wider offset.
Im coming from a 2017 with a shit ton of mods - was the suspension a straight forward install?
I have OME 888s with AAL in the rear
I have billies but they're shot so ill get new ones
Hey man, I just purchased front and rear suspension set up that came off of a 2020 TRD OFF ROAD Tacoma. Hoping it will all bolt up on my 2006 GX 470 sport model with KDSS.
Sounds like you were able to do this successfully? Where could I buy the replacement bushing that you said was needed for the rear shocks ?
Thanks in advance !
Thanks in advance !
Here’s the bushings that you need: Energy Suspension 9.8108G 3/4" Hourglass Shock Eye Bushing
You can find them on amazon for about $9.
There should be a sticky note for this info
I'm new to gx470 but think there should be a sticky note on what parts we can cross over from the 4r, tacomas and tundras.
Or if there is a place please share.
doing so much reading i'm overloading but this is info i'm down for. Compatible parts.
