high mileage timing belt parts list
nivlak
Hey guys so I am about to do a timing belt job on a new to my sister 4runner. it has 223k miles on the 2uz-fe V8. I have found in the sticky, a parts list but since this rig has some miles on it what should I include to make sure everything is up to snuff?
Someone else just asked this not too long ago and I just did the timing belt on my 04' V8 with 120k on the odometer...
I bought the Timing Belt Kit at AutoZone, had a Dayco belt, water pump, gaskets and all the components you need. I bought some spark plugs (figured I was already getting sweaty), antifreeze and a new FailSafe Thermostat. Total parts cost around $300...
Make sure you have a 22mm socket for the harmonic balancer bolt and a way to hold the balancer in place while you unscrew the bolt. I used a large chain wrench with a thick rubber strap underneath to protect the pulley. Also, a balancer puller (a steering wheel puller would work too if large enough) may be handy.
A cheap set of disposable ear plugs will help with the tranny lines though it may be a good time to flush that as well...
Good luck :)
Good luck :)
So there really is not other wear items that need/should be replaced then? I have heard of changing out the cam seals while in there...?
I am just wanting to treat this as if the timing belt has never been changed and to replace as much as I can since it might have been neglected.
Most kits come with seals, but 99% of people will only change them if they're leaking... I think it falls under the "if it ain't broke, don't fix it" rules :)
