4th Gen paint color code
Kmvreter
Does anyone have access to or know where to find the Toyota paint codes? I want to paint a project I'm making to match the truck. I'm specifically looking for the color of the silver accent bumper trim, the silver steel wheels (they look virtually the same so I hope they are the same code) or the interior silver dash trim. I only need one spray can at the most so I don't want to get hosed and buy the paint at the stealer. I need to match the code to something close that is off the shelf. I know this is rare but has anyone tried and had success matching the silver trims?
Thanks for the helpful info.
My door pillar sticker shows "C/TR 1E9/FG12"
I confirmed the 1E9 is the Galactic Grey Mica through the links given but I can't find FG12. I need to stop at Crappy Tire and see
if they carry Duplicolor here. I'm sure they or other stores would have a cross reference somewhere to the FG12.
Any ideas on the silver interior trim code?
When I did body work, I consulted my PPG supplier for interior paint colors. Their books have a guide as to the location of other build codes. I believe a Dupont shop could provide the same info to you. The reason I'd refer you to Dupont is that some suppliers can mix up the provided paint code into a spray can.
For a more practical approach, I would go with one of duplicolors high metallic silver. The 4Runners trim is a very bright and pure silver, that should give you the best match.
I don't think FG12 will tell them much. The body paint code is unique across all Toyota/Lexus products, but I think the interior trim color is more generic.
Here's the list of 4Runner interior codes:
FG12 - SR5 fabric stone
FG42 - SR5 fabric taupe
FH13 - Sport fabric charcoal
LB12 - Limited leather stone
LB42 - Limited leather taupe
tkr128 said:
Easy way to check is on the label by the driver's door jamb. On the lower right side of the label you'll find C/TR and then something like 8R3/FG42. Look at the code after the /
FG12 and FG42 are found on the SR5's (12 for stone and 42 for taupe.) FH13 is for the Sport Editions with the dark charcoal interior. LB12 and LB42 are found with the Limiteds (12 for stone, 42 for taupe).
Hope that helps. Your pictures look like the Stone interior to me, which should be FG12.
via tkr128
from...
Which Color iInterior To Do I Have (Pic Enclosed)
http://www.toyota-4runner.org/showthread.php?s=&threadid=26055
SR5
FG12 - Stone
FG42 - Taupe
Sport
FH12 - Dark Charcoal
Limited
LB12 - Stone
LB42 - Taupe
Thanks again for the help. Now I know what the FG12 is. I'll visit some specialty paint shops to find the interior silver trim color. Last resort is to stop by a stealership.
I guess I have to hit a good paint shop also. The graphite color #11GY10, does not come up on Toyota's computers. this is the accessory color on '06+ Sports.
