Old 03-12-2016, 08:48 PM #31
kevinnem kevinnem is offline
kevinnem is on a distinguished road
ugg.. broke vacuum line :(
Okay, so as it seems someone else already has done, I broke a vacuum line. It is so small at the back, and I was twisting the whole unit back on to the throttle body after cleaning and SNAP. I didn't even feel like I put that much stress on it..
ANYWAY...
This vacuum tube is AFTER the air filter, but that is all.
Can someone confirm what this is for? Is there a sensor in that upper housing piece (that holds the air filter)? or is it just a place it can suck clean air from?
is there some special air pressure in that housing? I imagine it is simply atmospheric as the airfilter (if not clogged) should let air pass un impeded.
IF there is not sensor, and it is only atmospheric pressure, can I just put a mini air filter on the end of my broken hose? Seems taht till be easier then trying to re-attach it?
I appreciate any guidance, and explanation you can give me. If you have any questions, or I have not explained it very well, let me know I can take photos or you tube or what ever.
kevinnem is offline   Reply With QuoteReply With Quote
Old 03-13-2016, 01:47 AM #32
ANYWAY...
Oh ,. and one additional thing, I *** THINK** ( could easily be wrong), that this goes to a fuel pressure regulator.
Old 05-16-2016, 11:37 AM #33
sherwoodpfifer sherwoodpfifer is offline
sherwoodpfifer is on a distinguished road
Great Writeup
Thanks for the writeup and pics. This was a huge help. I did this over the weekend and the old girl is running as good or better than the day I bought it. I have an 04 SR5 with 104K miles. The throttle body was filthy. It looks great now. Just a couple of things I would recommend during this process....
1. Use BG's Throttle Body cleaner (makers of 44K). It was great taking the gunk off with ease. I've used other brands and this one worked best.
2. Replace the O-Ring throttle body gasket/seal. It's $10 from the dealer or $7 for the fel-pro version. It's the easiest thing to do and should be done when performing this. My old one was brittle
sherwoodpfifer is offline   Reply With QuoteReply With Quote
Old 05-19-2016, 07:45 PM #34
Pilotamis's Avatar
Pilotamis Pilotamis is offline
Pilotamis is on a distinguished road
Pilotamis's Avatar
If I unclip the coolant lines, is coolant just going to drain out of them? I don't think it would if the vehicle is changed cold so it doesn't have any pressure in the line. I'd like to really be able to get in there and blast it clean and not worry about tweeting something.
Pilotamis is offline   Reply With QuoteReply With Quote
Old 07-04-2016, 09:58 AM #35
Sickoreo's Avatar
Sickoreo Sickoreo is offline
Sickoreo is on a distinguished road
Sickoreo's Avatar
Excellent write up!
2007 T4R V6 SR5 2WD: AFE Stage 2 dry CAI / Toytec BOSS 3''/2'' / Camburg UCA / OPOR Rock Rails / BFG KO2 275/70R17 DIY Mods: VSC TRAC Switch, Cargo storage box
Sickoreo is offline   Reply With QuoteReply With Quote
Old 07-04-2016, 11:57 AM #36
Silver_midlife_t4r's Avatar
Silver_midlife_t4r Silver_midlife_t4r is offline
Real Name: Adam
Silver_midlife_t4r is on a distinguished road
Real Name: Adam
Great write up! Did you ever find one for the V8?
2005 V8 Limited 4x4 - Bilstein 5100s front set at 1.75, Moog FJ Coils, Toyo Open Country AT 2 265/70R17, lots of Plasti Dip, under hood LEDs, AIP Bypass, interior LEDs, blacked out head & tail lights (my midlife crisis in progress)
Sold: 1990 Land Cruiser FJ62
Silver_midlife_t4r is offline   Reply With QuoteReply With Quote
Old 10-19-2016, 11:50 PM #37
3eyedRaven's Avatar
3eyedRaven 3eyedRaven is offline
Real Name: Hoop
3eyedRaven is on a distinguished road
3eyedRaven's Avatar
Real Name: Hoop
Def gonna do this after what I saw in my TB after removing that damn carbon filter. It was 'horrid'. Always finding good things on this forum. Thanks All!
3eyedRaven is offline   Reply With QuoteReply With Quote
Old 01-24-2017, 06:58 PM #38
myToyota4runner myToyota4runner is offline
myToyota4runner is on a distinguished road
Did this on my 1999 4Runner
I did this and made a video of it. Its pretty simple.
1999 Toyota 4Runner Limited Ed. 5VZ-FE 3.4L
https://www.youtube.com/watch?v=1bgt9FBQ1-E
myToyota4runner is offline   Reply With QuoteReply With Quote
Old 02-03-2017, 01:06 PM #39
krunner53 krunner53 is offline
krunner53 is on a distinguished road
Great write-up
This looks like very simple maintenance to do to my new to me 06 runner! Thanks!
krunner53 is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 11:15 AM #40
budlight94 budlight94 is offline
budlight94 is on a distinguished road
Rmps jumping
I have an 07 4runner, v8 4.7 motor. For the past couple of days when i'm driving and go to hit the breaks the rmps will jump and drop the level out. I have no codes coming up on the dash. Ive cleaned out the throttle body and it still does it. I can be going 45 and set the cruse and it will jump from 2k rmp to 2,500 then down to 1500 and back to 2k. When I crank it up, it use to idle at 500 to 700, now when I crank it up it jumps to 2k and will slowly drop to 1200 but won't go below that and it will bounce up and down a few 100 rmps just sitting there. Does anyone know what this could be?
budlight94 is offline   Reply With QuoteReply With Quote
Old 08-14-2017, 07:04 AM #41
Derek's Avatar
Derek Derek is offline
Derek is on a distinguished road
Derek's Avatar
Is there any way we can get the pictures rehosted?
Current: 2007 Limited
Previous: 2004 SR5, 2005 SE V8, 2007 SR5, 2016 SR5
Derek is offline   Reply With QuoteReply With Quote
Old 09-23-2017, 07:51 PM #42
ToyoNation ToyoNation is offline
ToyoNation is on a distinguished road
I have a 3rd gen. Should help, every car i have owned has slightly benefitted from MAF cleaning.
ToyoNation is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 04:42 PM #43
RazzRoach's Avatar
RazzRoach RazzRoach is offline
RazzRoach is on a distinguished road
RazzRoach's Avatar
can you spray throttle body cleaner in the TB and clean without unbolting it from the engine?
RazzRoach is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 10:57 AM #44
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Originally Posted by Duck'n View Post
All was going well until one of my throttle-body bolts broke! Now I am wondering if my torque wrench (not an expensive one) is suspect. I had it set to 15 lbs. and it seemed like they were getting REAL tight so I am thinking I have a problem with the wrench. Other than that, my throttle-body was FILTHY and it looks ALOT better. The MAF looked very clean but I sprayed it with MAF cleaner anyway. Now I just have to wait for the bolts to come in. I am getting chummy with the local dealers parts department!
For anyone who finds their way to this thread, this happened to me too the first time I cleaned the throttle body. I just cleaned it again today and was sure to set the torque wrench to 15 ft lbs. I don't know what the deal is w/ these bolts but I could sense 15 was too much so I lowered it to 12 and that still felt like something was going to break.
I put away the torque wrench and went with the time-honored method called "Tagn!" ("That ain't goin' nowhere!"), just snugging them down until they felt tight enough.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 11:45 AM #45
Anthracite85 Anthracite85 is offline
Real Name: Chris
Anthracite85 is on a distinguished road
Real Name: Chris
Clean!
Very helpful procedure for cleaning the throttle body on 4Runner. Appreciate the post!
2017 TRD Pro
Anthracite85 is offline   Reply With QuoteReply With Quote
