Steam from the rear
Dave718
Hey,
Looking for some advice here...
I have an '88 4Runner with an EFI V6, 5 spd.
When the engine reaches temperature, an area at the rear, passenger side of the engine emits a steamy cloud. Web research indicates a compromised cooling pipe...still researching this one.
No water in the oil, truck starts and runs fine, no rough idle or sounds during acceleration or deceleration.
What do I look for to trouble shoot?
Thanks!
Sorry I can't help, but I would like to welcome you! Check out the search engine above to find some answers. Don't use the google search box, but the search icon in the gray bar right above the box.
T4R.org is my favorite community, but some others are yotatech.com and toyota120.com
Hope your problem is a small one.
Where do you live, is it possible that the condensation drain for your AC evap is right above an exhuast pipe. That would explain a little steam with no other problems. There was probably an elbow there, may have fallen off and its draining right out on the exhuast pipe. If that is not it, then I would pressurize (sp) the cooling system and look for any leaks.
