swaybar disconnects
BuffsRunner
Im lifting my 2000 SR5 and was contemplating getting some swaybar disconnects from wabfab. Any opinions for or against it. Im lifting the 4r 3 inches and not planning on doing any extreme terrain in the immediate future.
If you're not planning on extreme terrain, I would not worry about it.
I made mine for my 03, it cost $1.60 plus tax. I simply took the sway bar links off and drilled holes through the bolts on them and put pins through them (.40 cents a piece) to hold them on. Make sure the holes are as far up the length of the bolt as possible so they are tight (I drilled the holes while the links were mounted to achieve this).
Look here to see what you should not do, I made this expensive boo-boo a few days ago
they do work, you will get more flex... BTW, when ever ya want to hit a trail, look me up :D
Re: Re: swaybar disconnects
Please do share, we would love to see just how you disconected the swaybars :bigok:
$3 or $4 is a lot cheaper than the wabfab ones for $135 plus shipping, I'll just have to make sure i watch out for the boot :)
well lets see what you got, lol "NO PICS, It didnt happen"
Im callin BS,, lets see the pics already
What is your ojective for the disconnect??
For flex?? >> just let a tire lift off a bit!! (turn on lockers & traction)
For smoothing out a rocky rough trail?? Greatly reducing air pressure works much better than disconnecting. If you still need more smoothing, then think about it.
Mainly for flex. I would love to turn the locker on but i dont have one, so when i say im stock i mean really stock. I still havent completely decided for or against it since i am still saving for the lift. But with my old jeep the disconnects made a huge difference.. so i was hoping it would make the same amount of difference with the 4runner.
