BuffsRunner
Im lifting my 2000 SR5 and was contemplating getting some swaybar disconnects from wabfab. Any opinions for or against it. Im lifting the 4r 3 inches and not planning on doing any extreme terrain in the immediate future.
BuffsRunner said:Im lifting my 2000 SR5 and was contemplating getting some swaybar disconnects from wabfab. Any opinions for or against it. Im lifting the 4r 3 inches and not planning on doing any extreme terrain in the immediate future.
Will816 said:If you're not planning on extreme terrain, I would not worry about it.
I made mine for my 03, it cost $1.60 plus tax. I simply took the sway bar links off and drilled holes through the bolts on them and put pins through them (.40 cents a piece) to hold them on. Make sure the holes are as far up the length of the bolt as possible so they are tight (I drilled the holes while the links were mounted to achieve this).
Look here to see what you should not do, I made this expensive boo-boo a few days ago
BuffsRunner said:$3 or $4 is a lot cheaper than the wabfab ones for $135 plus shipping, I'll just have to make sure i watch out for the boot![]()
