running lean at idle p0171 how long can i run like this for?
ian2328
ive been trying to hunt this code for a month before i finally got a smoke machine and found the leak in my intake gaskets. visually, it just "seeps" not billows smoke. already ordered oem gaskets but they might be here too late for me to work on it soon. the weekends are the only free time i get to work on the car and it worries me that its not running right. engine sounds fine, no pinging or rough idle just worse gas mileage. check engine light is off (chatgpt tells me the ecu has been able to compensate with more gas) but i verified the lean condition with a scan tool 19.5-30% LTFT short term is normal range, only lean under idle during normal driving it doesnt run lean. cooling system and ignition are in good shape.
thanks!
Often when I get your symptoms it's a dirty MAF sensor. I'd clean it with CRC Mass Airflow Cleaner, reset ecu & check trims again to see if it made a difference.
cleaned maf twice while hunting the code, unfortunately didnt make a difference which made me get a scan tool but at least now my maf is clean lol
So, find the vacuum leak... When vacuum in the manifold is high, it is pulling in unmetered air from somewhere. The fuel injectors are 'air assist' type, so there is a large vacuum line to those that run with the fuel rails that provides much of the idle air flow. If that pipe isn't hooked up to the intake pipe, it'll do what you are experiencing.
-Charlie
-Charlie
first sentence of my post.....? my question is if i have to worry for a week or two if i cant get to the gaskets due to shipping since the lean condition doesnt trigger a CEL
Dabbing a bit of RTV where its leaking will take care of most/all of the leaking, at least temporarily - and should take just a few minutes. I'd also do a quick bolt check to make sure the nuts/bolts are tight. Those gaskets are pretty robust, so I'd suspect contamination or loose fasteners.
-Charlie
ive been running my dads 1999 for about 6 months on a to lean code, we diagnosed it to be a mass air flow censor and the intake air temp censor. that seems to have been the problem but it still idles at differnet speed so i think there may be an uderlying vacume leak, that all goes to say you should be good for a while before you fix it. anothere thing we had problems with was a failed pcv valve, and that will also make it run like like crap. if you do replace those make sure you get the metal ones as the cheaper ones do not work.
did the repair this weekend and runs great now. if you dont have a smoke machine id highly recommend a cheap one off amazon. will prob have to do the pcv again at some point, went with a basic amazon one just bc it got there in time to put the car back together :/ but so far no problems yet.
I have a smoke machine but haven't used it yet... At what locations did you introduce smoke for the 5vzfe?
unplugged the hose shown and blocked off the end of the intake tube with a bag and fit it back over the maf to create a seal.
youngrk
