5th Gen Toyota 4Runner Lower Control Arm Skid
RagoFabrication
Gain the protection you need while out on the trails with the Rago Fabrication Lower Control Arm Skid. Our 3/16" P/O steel is laser cut for the perfect fit on your 5th Gen 4Runner. Our design has a fully welded front plate that layers the main body for extra strength. The front edge design is engineered to conquer the toughest terrains while the back is designed to prevent you from getting stuck while rolling backwards.
*Please check your clearance of the backspace for your rims prior to purchase. If you have an offset then you will need to make sure you will have clearance between the LCA Skid and your wheel/tires. We have 17" Rims with a -10 Offset and clearance of roughly 1 inch at full rotation for an idea of what you will need for your vehicle.
The Details
Made in the USA
Easy 20 minute install
NOT COMPATIBLE WITH ALL TRD/ TRD PRO MODELS, FACTORY SKID PLATE or KDSS
Kick-out for additional protection
Laser Cut and CNC Bent 3/16" Cold Rolled Steel
Raw Steel or Powder Coated Textured Black Options
All hardware included
No Drilling Required
Read more about this product on our Lower Control Arm blog.
Have a Factory Skid Plate? Check out the TRD Pro Lower Control Arms. The TRD Pro Version is designed for factory skid plates whether they are TRD's, TRD Pro, Sport or other Factory Skids.
4Runner | Lower Control Arm Skid | 5th Gen – Rago Fabrication
