O2 sensor and Oil pressure sending unit location
chimpmunkproof
Hey guys I was going to put on a Oxygen sensor extender in and was wondering where it is on my 2000 4 runner its the 4 cylinder version. I was also wondering where the oil pressure sending unit is located?
thanks a bunch
this might help
REMOVAL & INSTALLATION
When troubleshooting a suspected oil pressure problem, it is possible to remove the electric oil pressure gauge sending unit (switch) and install a length of appropriate size oil line and a mechanical gauge. This is often the best way to determine if the instrument panel oil pressure gauge is faulty, the electric gauge sending has failed, or if the engine oil pump really is putting out only low pressure, endangering the engine.
If equipped, remove the lower engine splash shield.
Due to the shape of the switch body it may be necessary to use a specially-shaped socket. Toyota recommends their Special Service Tool (SST) 09816-33010 or an equivalent oil pressure switch socket. Using an appropriate socket extension, as required, remove the switch.
Fig. 1: A special socket is used to remove the switch
Fig. 2: Apply a thin coat of adhesive such as Loctite
Disconnect the negative battery cable.
Ensure that the engine and exhaust pipes are cold. Locate the oxygen sensor in question. There should be one in front of the catalytic converter and another behind the catalytic converter. Vehicles with dual front pipes will have four oxygen sensors, depending on the engine.
Some oxygen sensors thread into the pipe, others mount with two studs and nuts. Spray penetrating oil on the studs to ease removal.
Fig. 1: This O2 sensor is mounted with two studs and nuts. Use a penetrating oil to ease the removal of the mounting nuts
86824p87.jpg~original
Fig. 2: Use a closed end wrench to remove the mounting nuts
93164p12.jpg~original
Fig. 3: Unplug the O2 sensor harness
86824p85.jpg~original
Fig. 4: It may be necessary to use a deep socket to remove the mounting nuts
86824p86.jpg~original
Detach the oxygen sensor wiring.
Remove the oxygen sensor retaining nuts, if used, or with a suitable wrench, unscrew the sensor if it is the thread-mount type.
Remove the oxygen sensor and gasket.
Fig. 5: Remove the sensor from the pipe
93164p11.jpg~original
Fig. 6: Remove the gasket from the studs . . .
93164p09.jpg~original
Fig. 7: . . then discard the gasket and replace with a new one during installation
93164p08.jpg~original
Fig. 8: Most Toyota oxygen sensors are of the four wire type
93164p04.jpg~original
Fig. 9: Typical Toyota oxygen sensor wiring harness
93164p05.jpg~original
To install:
Install the oxygen sensor with a new gasket. If a thread-type sensor, apply an even coat of anti-seize compound only to the threads. If a stud-mount type sensor, apply a coating of anti-seize compound to the mounting studs. Install the nuts and tighten to 14 ft. lbs. (20 Nm).
Connect the oxygen sensor wiring.
Connect the negative battery cable.
MVD310
