'00 4Runner Lift Kit
ehub1304
Hey guys, brand new to this forum. i just got a 2wd (unfortunately) 2000 4Runner and am looking to do some modifications to it. does anyone know where to get a good lift kit for a 2wd 4runner and i'm also looking for a nice grill guard.
thanks!
-Eric
if you wanna go cheap you can always do daystar. they make a 3 inch coil spacer lift.
grille guards i'd go Westin or a cheap Hunter one off eBay are pretty good.
o.k. i just went through your whole thread...where did you get your kit and did it come altogether as one or did you piece it together?
ok so i've looked around and have come up with this:
3" Lift with spacers from toytec: http://www.toyteclifts.com/index.ph...ategory_id=71&option=com_virtuemart&Itemid=72
2" Body Lift from 4crawler (kit d): http://www.4crawler.com/4x4/ForSale/Toyota4RunnerBodyLift.shtml#GenIII.2
comments? is this a good combo?
Are you going to put both of them on? What size tires are you trying to run? I wouldnt do spacers and body. One or the other. You can do new suspension and a body lift though..
Yeah get the first one. Its fine and you can do a body lift too. What size tires are you trying to run?
Yeah. You can fit 265 right now without any lift. 285 with the suspension lift then with the body lift 315's..
what could i fit with the same lift and just a 1" body kit? also...would i be able to get the tires that are just 2 digits (i.e. 31" or 32" etc...) or should i just stick with the tires that are like the 285/x/x etc...
lift...
hey man...i wound definitely not get 265s, im running those on my 2000 4runner right now without a lift. im actually trying to do the same thing as you (getting a lift and some tires). im getting that first lift that you wanted to do and im getting either 285/75/15s or 33s. probably nitto trail grappler m/ts
