01 dome and map led swap
01thunder
i read alot of write ups for 98's and older but how about for 99 and up? i want to swap the domes and maps for led's. i have seen the festoon bulb as well as the panel with festoon adapter.
who has done this swap and what works? like some or most, i have spent on trial and error bulbs with some working, some not. so what exactly do i need for these applications, as well as for the shifter light and license plate?
Nice font... try using the search function this has been covered 8 million times. Its not that hard to pop of the map/dome light and see what kind of bulb it is, i don't understand why people keep asking this.
|March 10, 2011|
Here is where I ordered my parts:
Dome lights: Oznium.com: $35
Flexible 5mm LED Dome Light
Each LED comes with a set of ‘dummy bulbs’ with easy plug-in wiring to the LED board. These things are crazy bright!
Dash Lights: Autolumination.com: $55
Autolumination Instrument Panel Light Bulbs & Lamps)
--For the 2002’s, almost of all the bulbs you need are #74’s. The climate control uses a few Neo-wedge bulbs.
ECT/rear window:2x Neo-wedge type A
Climate controls:3x Neo-wedge type B
Gauges: 3x #74 (#24) Matrix 5-LED (Type 1; with 3 LED on top, 2 on sides)
Key ring:1x #74 Single LED Superstar
Glove box light: 1x #74 Any style that is narrow
Tranny Shifter:1x #74 Any style that is narrow (Note: there is a green film on inside the shifter, so a white light here did not change the color)
Ash Tray Light:1x #74 Matrix 3-LED (Note: my ashtray light is used in the stereo pocket)
Other useful threads:
http://www.toyota-4runner.org/3rd-gen-t4rs/78310-led-conversion-questions-2.html#post870257
http://www.toyota-4runner.org/3rd-gen-t4rs/35104-led-lighting.html
http://www.toyota-4runner.org/3rd-gen-t4rs/79771-you-can-change-color-your-clock-2.html
http://www.toyota-4runner.org/3rd-gen-t4rs/83928-changing-bulbs-c-unit.html
LEDChart_zps5ff5a07b.png~original
Before; Look at all that green!
100_0649.jpg~original
LED dome lights and cargo lights:
100_0452.jpg~original
Tearing the dash apart:
100_0652.jpg~original
100_0675.jpg~original
Back side of Gauge cluster:
100_0679.jpg~original
Wax paper to eliminate hot spots:
100_0666.jpg~original
100_0687.jpg~original
100_0688.jpg~original
Gauges:
100_0695.jpg~original
Overall: :art:
100_0752.jpg~original
(sorry for pic quality on that one: 4 second shutter time on night time mode is tough)
lindwlson982
