1800AskMatt
Hello everyone!
My 01 4runner SR5 2wd 3.4 w/ auto, has developed a vibration under acceleration pretty much at any rpm.
It started after I towed an empty tow dolly back to U-Haul for a friend. The dolly road like a jumping bean the whole way. (and I understand they smooth out with a car on them
Now my truck feels like it vibrates the whole frame after 5-7 mph and up.
I pulled onto the main street this morning and rolled back a little on the incline and something "popped" under the drivers side floor board and then rattled for a few seconds, then stopped all together.
The vibration will go away for about 30 seconds every once in awhile.
I can feel the "vib" in the floor board and the gas pedal along with the shifter.
The "vib" causes a droning hum to the entire inside of the truck almost like driving on the rumble strips on the right side of the road that wake you up if your veering off, but not violent shaking.
The truck doesn't shake like like wheel balance. I had them done 2 weeks ago with the alignment after my suspension lift and wheel spacers.
If I shift into "N" the "vib" tames down and the cab of the truck gets quieter.
Then put it back in "D" and it does it again in about 5-10 seconds.
The steering wheel is smooth and going down hill with no load, make less vibration until you accelerate again.
My trans fluid looks good and doesn't smell and is at the proper level.
No leaks showing.
All heat shields look to be tight and so do the motor and transmission mount.
Universal joint feel tight and look fine.
ANY SUGGESTION?
Any would be VERY helpful as I am scared it is my torque converter getting ready to go.
Thanks in advance!
:zoom:
No leaks showing.
ANY SUGGESTION?
Thanks in advance!
:zoom:
