02 4Runner Interior Lights?
Fo_SheeZy
Altight I've changed my center & trunk dome lights, but I can't seem to figure out what type of bulb that is for the two lights up front. I think they are called "map lights" there's one for the driver and one for the passenger. Anyone know what type of bulb that is?
i used 3022-B9 blue 9 led for my map and courtesy and trunk light, it fits my 96, i ono if itll work for u, but u knoe its a festoon bulb
Map light
DE3022
Step/Courtesy light
DE3021
DE3022
DE3175
Trunk/Cargo area
DE3175
I just replaced my "map lights" with super white leds. They are the Ba9s Bayonet Base Matrix 5 Led Bulbs from autolumination.
I bought mine from autolumination.com. If you scroll down youll see this one(the one you want for the map lights):
What about the 2 bulbs right above the rearview mirror? I cannot find a replacement bulb that fits those slots. Looking for more of a "white-ish/blue" light bulb, but still no luck.
They are bayonet base bulbs, here is a diagram of the specs.
D-chill said:
Rock Slide, I'll take a pic of mine tonight if that would help?.
EDIT:
At first I thought that'd help, but then again a bulb's a bulb. (Thanks for the help though.)
Instead, if you don't mind, could you simply point me to the right spot as to where I can purchase them on autolumination? I've looked all over that site and could not find them...I must be looking in the wrong spot. Thanks!
(I did not realize that was the bulb you were taking about in a previous post)
Are you serious? I swear I ordered those.. I must've ordered the BA10's or BA15's.. What year is your 4runner?
Rock Slide said:
EDIT:
D-Chill, never mind on getting me that link. I searched and searched and finally found them. Thanks! Ordering them now.
Oh, my fault. D-Chill do you what type of bulbs it is to replace the A/C Controls. I know it's this one right here
"Neo - Wedge LED Instrument Panel Bulb"
But I'm not sure if it's Type A or B
Type A is 8mm= 5/16"
Type B is 10mm= 3/8"
Any idea?
http://autolumination.com/74.htm
Rock Slide let me know how they work out. I've noticed the light on the driver's side will flicker occasionally.
Interesting...
I'll let you know how mine turn out. Thanks again.
Received my order Friday. However, they sent me the wrong LED map lights :mad:. They said to send them back and they'd send me the correct bulbs. So no update yet on how well the map lights work.
I will say both the LED dome and cargo lights work great!
I'll let you know how the LED map lights turn out. Should have them in a week or two.
