02-4runner slip control
robus
02-4runner can I stop the tires from slipping?
when my tires slip, all engine power is lost
I find this to be extremely dangerous
when I can not make my tires turn
Can anyone help me resolve this problem
No solution to your problem. If you're off-roading, then lock the center differential...and this will disable VSC (stability control). Otherwise, on-road, there is no way around this except if you pull out the fuses which will confuse the hell out of your computer.
Solution: get used to it.
actually.... there is a way around ATRAC, im not sure if this is what Thai was speaking of when he said pull the fuse, but you can pull the plug on the front side of your master cylinder and that will disable ATRAC, but it will also disable ABS. the safer way to combat this is to lock up your differentials (aftermarket parts) so ATRAC will never come on.
are you speaking of onroad or offroad?
