03-09 Front Daystar Spacers FS
climb.on
I have a set of 1" Front Daystar Spacers (gives about 2" of lift) for sale if anyone is interested. For all 4th gen 4runners 03-09 with or without XREAS. Item pictured is exactly what you will get including Daystar's instructions. These are brand new, never used.
There is a great writeup of the install HERE. My WRITEUP may also be helpful.
I'm selling because I decided to go with a different kit. PRICE $40 shipped to your door (48 states).
This kit mounts on top of the upper strut coil support plate and doesn't affect the actual spring rate. That means the ride firmness will feel similar to stock after installation of this kit. Comes with necessary longer stud kit.
Respond here or PM me if you're interested.
climb.on said:
Still available - although I have another interested party. First one with payment gets them.
Couple of questions:
1) Is this a top out spacer (mounts on the top of strut)?
2) Can please measure thickness of that spacer?
I just finished talking with
Wheelers info is incorrect, been discussed before, youd be better off to get the info direct from the OP...which was clearly stated in the first post.
climb.on said:
It is the top out spacer and it measures 1 1/8" thick (not including that raised center section). These were bought from Wheelers and are the ones on their site that say "4Runner 1.25" Lift Front Coil Spacer Kit". It will yield about 2" of lift. I think whoever you talked to there is incorrect. There seems to be A LOT of misinformation out there about the Daystar spacers.
Thank you!
I will have to think about it, as I am not planning to install any spacers in the rear and I think 2
