'03 4Runner with 101K ...Need Servicing Advise??
BnVs
Folks,
Was a BMW fan since I was a teenager, but finally grew up to the 4Runner. My question is (Experts) I've got my 2003 4Runner and it just hit a 101K miles. I've taken care of it and serviced it regularly. I need a detailed list of what all servicing needs to be done....(Shown in a list format and reason for servicing) I searched out here on the forum and I didn't find anything. Please can someone come to my rescue before the Stealership rips me off. I'd appreciate all the help I can get. BTW, I never knew they had a site for 4Runners....
Thanks,
BnVs - Atlanta
678 524 8300
P.S. I'm in Atlanta, so its a 2WD V8 Limited w/ the timing belt.
I just copied this straight from Toyota's owners site, under maintenance schedules. Hope it helps. Sorry I can't provide any more input as I haven't even reached that kind of mileage yet on my 4runner. There are also probably some minor differences if you have a V6 or V8.
http://smg.toyotapartsandservice.com/guides.php?v=1&y=2003&int_id=67
2003 4Runner
100,000 Miles - 60 Months
Replace engine oil and oil filter
Additional Maintenance Items for Special Operating Conditions:
Driving on Rough, Muddy or Snow-Melted Roads
Inspect ball joints and dust covers
Inspect brake linings/drums and brake pads/discs
Inspect drive shaft boots (4WD)
Inspect nuts and bolts on chassis and body
Inspect steering linkage and boots
Lubricate propeller shaft (4WD)
Re-torque propeller shaft bolt
Rotate tires
Driving on Salt-Covered Roads
Driving on Unpaved or Dusty Roads
Inspect engine air filter
Replace air conditioning filter
Extensive Idling or Low-Speed Driving for Long Distances
Towing a Trailer or Using a Camper or Car-Top Carrier
From reading a Tundra Forum, they usually replace the following:
Serpentine Belt, Timing belt, Idler Pulley, Tensioner, coolant, water pump, & spark plugs. This comes to around $ 350 $ 450 dollars depending on if you use OEM parts or not. Labor is around 5.5 hrs @ 65/hr = $ 357.50 plus tax. Throw in anything else that may need to be done as well (like diff fluid, ATF, Transfer case etc) and you are looking at prices that are between $ 800 to 1,200 smackers.
Notes: this is the 120 k miles service for the V8 since it has a timing belt, but many will do this at 100 k miles instead.
greasefingers said:
Notes: this is the 120 k miles service for the V8 since it has a timing chain, but many will do this at 100 k miles instead.
Grease, I believe you meant Timing Belt and not chain??? It was my understanding the4.0L V-6 has a timing chain and the V-8 has a timing belt. Unless I misunderstood????:cool:
I just got done having my timing belt (yes, it's on a V8) changed, and it ended up costing me $1200 for the belt, pump, seals, idlers, serpentine, coolant, etc. I've already changed the transmission fluid at 60K, along with the xfer, diff cases, so that will be good until I change the plugs, wires, etc. at 120K. I'll probably go ahead and change my brakes then as well (unless they go out any sooner), so that I can go ahead and replace the lines to SS, and replace the fluid as well to a better grade.
You are supposed to change the timing belt at 90K. The V8 is an interference engine, so if the belt goes out....FUBAR!
'03 V8 SR5 4x4 102K
Thanks for catching that for me :yesyes:
