03 dash lights out
Presta24
I have an 03 where the dash lights(display for time and temp) have all gone out, to change ac/heat temp i have to turn overhead light on. Dealer wants a ton to fix, has anyone had this problem and repaired themself?
how do u pull the panel?
Just remove the little storage thing under the AC unit. Open it, pull straight up and out. You will see a 10mm bolt. Remove that, and then the panel just pulls out. Start at the lower left side, and just work your way around. Its in there pretty good, but you wont break anything.
edit-You will need to disconnect the main wiring harness going to that unit, after popping it out. This is obvious, but I figured i should add that it wont mess anything up. Remove that, look at the rear of the unit, and you will be able to see the bulbs.
