03 Reprogram drivers window & Sunroof
Biff
I had to disconnect my battery for a few minutes to do some electircal work on my rig. When I reconnected the battery back up I noticed the drivers window as well as the sun roof don't open up with the single touch to the control, you have to hold the button down like you do with all the other windows. Does anybody know how to reprogram the system to make the windows come down with a single touch?
When I put in the aircharger I had to reporgram the auto up/open feature. This is how I did it. Start with the window up/closed, then put it all the way down while pushing the switch, then let go. Now put it all the way up again, holding the switch again. They should be reset. Let me know if this helps. Try it a couple of times if it dosen't work. Hope this helps.
Thats perfect, worked like a charm. Thanks alot for your help.
Crookedcat
