At HWY speeds (50+ MPH), going over bumps produces some serious shuddering and secondary vibrations through the steering wheel, to the point where it just shakes in your hand like severely out of balance tires... but only when going over bumps or on poorly smoothed concrete surfaces. So... I know it's not the tires.
I don't recall these vibrations when it was new... or having them for more than the last 4-5 months or so.
The dealer tells me my front shocks are leaking severely (visually I can concur w/ that as oil has coated the bottom half of the spring). At 62K miles w/ no offroading or towing, only loading up w/ the occasional 25 bags of mulch, seems pretty rediculous to me they would've failed already.
I also have trouble believing new front shocks is going to solve this problem because it seems the vibration / shudder frequency is too high to be soaked up w/ shocks (as opposed to a worn shock bounding up and down at a significantly lower frequency and/or causing the vehicle to float over undulations, which it also does).
What do you think? Do any of you have similar issues w/ your 4-Runners? Is this an aging thing I'll have to live with or do you think the shocks will actually solve the problem? At $850 installed... I want to be sure...
Thx!
Thx!
