03 V8 Timing Belt replacement plus???
dweyer
Im taking my 03 Limited V8 2wd in for timing belt replacement with 92k miles. From what Ive read on other threads I should go ahead and also replace what?
1. water pump and thermostat
2. seals and something???
3. serpentine belt
4. radiator hose plus new coolant
5. plus....
I hope to experience life for another 100k miles without a car payment so preventative maintenance is important. As a side note I have found this forum to be very very informative and cost saving. I recently replaced a magnetic clutch relay myself and saved probably $50 or more. I used the flashing AC button light symptom to diagnose and bam I found the answer. I wish I had found this site when I experienced the infamous lower piston caliper seize! Thanks for all the expertise!
I just had my timing belt, water pump, thermostat replaced for $ 866 without tax preformed today at the dealership. I have 99,940 miles on her.
