04 Air circulation?
rabeet
For whatever reason I just noticed that whenever I start up my 04 SE V6, the air circulation switch is on. That is, air is recirculated rather than fresh drawn in.
I looked over the manual and found nothing on this.
I could swear it has not always behaved this way.
Is everyone else seeing this??
does it revert back to recirc. even if you turn if off and then turn the vehicle off then on again?
it should remember the last setting it was at when you turn the vehicle off then on again.
Recirculate
I have just noticed the same thing - it seems to default to recirculate, instead of fresh air, like most cars. And I don't think it has been that way all along. Wierd.
Are you hearing those voices it makes too?
Jim
temperature
i think it has to do with the temperatue settings...if the air outside is warmer than what you have it set for, than it wont draw in the air from outside, it will recirc whats in the cabin. try turning the temp above 20, and im sure it will go off...
It is weird because if you manually control the recirculate button, it does not turn off the auto light. When you change any other setting (fan speed, air direction), it turns off the auto light. That is why I do not think that this is controlled automatically. It would probably take the system out of automatic.
The recirculate function goes on and off automatically depending on both the outside temperature and the interior temperature setting. I haven't noticed this 'feature' since the outside tmperatures dropped last fall, but I know it will be back in the spring now that things are beginning to warm up.
This really bugs me too because I get a little claustrophobic when the recirculate is turned on. I gotta have fresh air! It goes back to a traumatic high school car pool experience where the driver would never have any air flow and the windows would get all fogged up...oh man, I feel nauseous just thinking about it.
Anyways, I discovered a new feature quite by chance, maybe it is well known? When the climate control is set on automatic and you manually change the airflow, the system goes on manual. If you hit automatic again at a later time, the system returns to auto mode but turns on the a/c button whether or not it was on before you forced the system into manual mode. I keep that little button off unless I realy want the a/c compressor running so going back to automatic is a two step process - first press auto button, then press a/c buton to turn the a/c off. Are you still with me? Here is the interesting part: if you are in automatic mode and you hit the front defrost button (to quickly clear a foggy windshield), the system will go to manual as usual. If you hit the defrost button a second time, the system will go back to the previous setting. It even remembers if the previous mode was automatic with the a/c button turned off. Other options do not appear to work this way, only defrost.
I was pretty excited when I figured this out. I guess it's the little things in life that matter...
I also found out something interesting a couple of weeks ago. When I started my car on a cold damp morning and went to turn on the front defroster, I realized that it was already on. I had the system in full automatic mode. The system also controls the front defroster. It turned it off after a couple of minutes and the window was clear. It has turned on the defroster numerous times. I mostly have to manually control it though when it is warm outside!
if you do a search, there are other threads about the auto climate control in the 4runner. i personally dont like how it decides on what to do, so i just manually control it. at first i thought it was a neat feature, but now after living with it, it never picks the settings that i want.
ie: i dont need any type of a/c when its -40F outside. i want heat to defrost the front windshield.
At least I know I am not crazy.
Or that my 4Runner has a problem. :)
I am of the fresh air all the time school. I would much rather have completely manual control over the heat/AC. Ah well.
Speaking of which... so when will this truck have a problem?
I have never owned a brand new car that didn't have at least one minor defect that needed fixing.
:confused: What the heck is Toyota thinking?
