I hava an 04 V6 Limited, which I bought used this spring. It's had one recurring problem and one very strange problem. The vehicle often goes completely through the start cycle without starting. If you have a car that starts, you might not know that the starter will only crank for a certain number of times before it stops. It always starts right away on the second try. This always occurs when it's warm. I thought it might be bad gas, but it doesn't seem to discriminate too much. I had it into Toyota today for an oil change, and the service writer thought it might be dirty injectors. I don't know if this has been directly addressed in other threads, but I'd appreciate some help.
The second problem is much stranger. Twice the car has started itself. The first time it happened when I hit the door lock button. I had just purchased the car, and figured I had a remote starter that I wasn't told about. However, the key wouldn't turn it off, and I had to put in gear to stop it. The second time it started when I used the key in the rear door to close the window. I was using the key, because the window switch and the key fob control had both inexplicably stopped working. After the car started they window controls started working again. This has only happened these two times, and needless to say Toyota is clueless. Am I the only person this has happened to, and does anyone have any idea what this might be?
