I’m having the following lights come up on my dash - traction control, vsc trac, vsc off and abs lights - And I have no idea wtf is wrong.
https://imgur.com/gallery/e1VCWGR
So I have an 05 SR5 with V8, a little over 110k mikes.
Around 109k, I had a shop do the following:
New cv axles from Napa (seems to be the best value for a non off roading truck).
OME shocks and coils (2884 in the front and 2895e in the rear).
New front calipers, rotors, pads.
New falken wildpeak at3w in 265/70/17 vs the oem of 265/65/17
New rear rotors and pads
New brake fluid.
First 1200 miles on this setup, zero issues at all. Car drove great, gas mileage went down a bit, and it brakes great.
One morning, it’s 19 degrees out, let it warm up a bit then start driving. When I pushed my gas pedal down, it felt like the abs was instantly kicking in. Brake pressure felt firm compared to a bit squishy that I’m normally used to. Brake again and same results. Pulled over to wait a min and those lights appeared. Drove carefully and made it fine.
Went to my shop, the lights had been coming and going. Told them about the lights, they checked the code and saw the front right abs sensor had gunk on there. Maybe from the cv leaking. Drove home and no issues for a few days.
Then it all came back and it’s intermittent. Lights come and go. Brakes feel fine then they feel weird.
So the issue with the brakes now is as I slow down and lightly hit my brakes, i hear a buzzing noise coming from my dash, the brakes brake in a wave form it feels like- like abs kicking in hard then letting go then grabbing hard quickly. Lights will come back. Then I brake again and it’s completely fine.
Any idea what this could be? Bad brake sensor? Air in my abs system when the did the flush?
New brake fluid.
