A year old brake pads squeal at low speed/light press - issue?
deevilla7
Junior Member
Hey all, I have 2020 TRDP at 84K miles. Wondering if you can help me identify the brake issue before taking it to the dealers.
I had my all of 4 brake pads replaced and rotors resurfaced about 20K miles/1 year ago.
For about 6 months or so I get random brake squeal (more light but high pitch), whenever the vehicle rolls with brake slightly pressed. For example going through drive-thru or pulling into a garage for parking.
On normal driving situation, brake is fine and no sound when I come to a stop.
The problem is sometimes it happens, sometime it doesn't. Also it seems to come from the front(?). It almost feels like has to do with weather too. I feel like it doesn't happen during colder weather.
IF any one can help me identify before I take it to the dealers, because randomness of the noise might not help my situation with the dealer (if they don't hear it).
Thank you in advance.
It could be brake dust accumulation or the shim pads or pins weren't lubricated enough. You cam use brake cleaner to clean off the brake dust bit try not hit the lubricated parts.
It could be brake dust accumulation or the shim pads or pins weren't lubricated enough. You cam use brake cleaner to clean off the brake dust but try not hit the lubricated parts.
DevinG93
