05 SE with clunking sound
Hot Rod
I have an 05 SE 4x4 with V8. After i stop and let off the brakes i hear a loud clunking sound as if one of the brakes did not release with the others. It is definetly in combination with the brakes as this is when i hear it and at no other time. It does not happen all the time but at least 3 out of every 10 stops. Any ideas or anyone with this same problem. I am taking it to the dealer Friday but just wanted to see if this is an ongoing problem.
clunking sound
Hot Rod, odds are it's the drive shaft. I have a newly purchased 2003 SR5 V-8 and a few starts and stops after buying it I heard and felt the same thing. Having owned a few chevys I immediately remembered it from then. Either go to your dearler and have them lube ALL the fittings (about 9-11, can't remember) or you can do it yourself. Easy job, it will take longer to jack up your truck and put down the stands than to do it. good luck, CSM-H
Do a search on this topic. I can't find the thread right off hand, but there is tons of discussion on this. The concensus from what I had read seems to be a good lube job underneath (particularly the driveshaft) will take care of the problem.
This is a well-known phenomenon which afflicts many 4X4 trucks.
What's happening is the slip yokes that allow the drive line to shorten and lengthen are binding when you create a little axle wrap by using the brakes. When you stop, the binding lets go and the "thump" occurs.
My '98 'Runner did this if I missed lubing the slip yokes at my 6K mile oil changes, and so did my '03. Lube the slip yokes and it'll go away. Break-in of the slip yokes apparently plays a part in loosening them up as well.
Toyota used to recommend NGLI 2 grease with Molybdenum disulfide for the slip yokes, and I found that works well. I'm currently using a Valvoline synthetic grease with Moly added and haven't heard the "thump" for a couple of years now.
Regards.
I am convinced that mine will never go away. Each year I jam six slugs of grease in that slip joint with no avail. Eighteen slugs so far.
It went to the dealer today and it was done in an hour. just like you guys said it was a grease issue. Thanks for all of your help it aided in steering those guys in the right direction. They should have a link to this site. LOL
