06 4Runner Limited Lift Questions
blackout00
Hello Everyone. First of all what a great forum! Great info. I was looking for some guidance on lifting a 06 4Runner Limited. Here is what I am going to do so far:
Lift: Toytec 3 Inch Spacer and Rear Coils
Tires: Kinda Stuck here. I want BFG AT but what size can I run on the stock wheels? Do I need the SpiderTrax Spacer? What advantage do these give?
Wheels: I want to keep the stock wheels and powder coat them gloss black.
What am I missing? Any help is greatly apperciated!
Tires: Kinda Stuck here. I want BFG AT but what size can I run on the stock wheels? 275/70/17 or 275/65/18 works very nicely and you can carry a spare. Do I need the SpiderTrax Spacer? What advantage do these give? Probably. These will push the wheels out a bit and prevent UCA (upper control arm) rubbing. You will need to do minor trimming as outlined at the bottom of this page. You may need some minor mudflap trimming as well. The rear should be fine.
Wheels: I want to keep the stock wheels and powder coat them gloss black. Stock FJC rims or previous gen Tundra/Sequoia rims look great too and they have a more favorable offset (tire sits a bit farther out, 15mm each side IIRC). Maybe a used set of those in 17" might be a nice option. You may or may not be able to skip the Spidertrax with these rims. Someone else will have to chime-in.
:cheers:
Do you have the air-ride suspension option? If so thats a whole nother ballgame!
Forgive me for asking what is probably a very stupid question but...I just purchased an '03 Limited V8 w/X-Reas. How can I tell if it has the air suspension option? I know, a very stupid question.
Thanks in advance for the help.
On the center console, behind the gear selector, next to the DAC button will be a button for it.
Same
Just ordered the Spidertrax from Jason Burtman at Burtman Industries, should be here soon. Want to:
3/2 Cornfed Spacers
Powdercoat rims and badges black
Possible Demello Sliders
Possible Roof Rack of some sort
