06 center speaker
jonhul
Could someone give the location of the center speaker with a 10 speaker setup. I have 6 speakers and want to add the others. It sure would be helpful if you also knew the part number. Thanks
It's not worthwhile IMO. You would need a new upper dash with the cutoff for the center to add it and that will be $$$. I had the 10spkr JBL and gutted it for an aftermarket 4 spkr setup. I kept the very rear pair of speakers in the pillars for rear fill. Sounds VERY nice and I don't miss the stock center at all. Spend the money on a nice speakers and don't bother with the center.
Thanks. By your response I'm assuming you are saying the center speaker is located in the top of the dash- behind and above the HU. What about the sub box in the rear panel- did you remove it also? I was intending to add it also.
