dones any one no what size speakers and tweeters are on the 06 sport model i think there are a total of 2 tweeters and 4 door speakers and what what would u recomend as an up grade
-thanks
I just installed some Eclipse 6x9 4 way in the front and some 6 1/2 3 way in the back. There are better ones out there, but for the price these sounded good.
Here is what I just found out (i too will be upgrading real soon)Fronts are 6x9 but beware...only 1 3/4" clearance with window down. You can use a spacer because you have ~1.5" clearance between mounting surface and inner door panel. Tweeter mtg will need to make up a mounting pc. (i'm going with a\d\s 246ix seperates)
Rears are 6.75" 3 point mounting, (try Polk 6 3/4" db675) and will require a speaker adapter to go to 6.5". Here there is ~2.5" clearance with window down and ~ 1.5" clearance between door and panel. (I am going with my old Kicker Impulse 6.5" seperates)
check here for some elses pics. This is a 2003 but it's the same.
