06 rear wiper ?? & seat squeek
Falls
Super Moderator
My rear wiper seem's to have no power, it work's sooooo slow and there is no diff. in speed betewwn low and hi setting. I timed it and it's alway's the same slow speed. Anyone else notice this or do I have an issuue with it?
Also the rear seat squeek has reared it's ugly head. I'm sure an easy fix and I'll try to get it to stop on my own. I think someone did a little blub/write up about the fix. I'll do a search and find it.
For the seat rattle, I put electrical tape around the metal loops where they attach to and that solved my problem. I haven't checked my wiper to see if there is any difference so can't help on that one.
Scott
On Low, my rear wiper pauses between wipes. Hi is continuous wipes, no pause. If you turn the switch past Hi, it will squrit washer fluid.
Because it rarely rains in southern California, I use to always accidently turn on my rear wiper instead of my front wipers. I keep twisting the wiper knob while forgetting all I have to do is move the lever up or down.
It makes you look really stoopid at night when you have to turn on the interior dome light to figure how to turn on your freakin front wipers!
:bash:
To answer your question.......my rear wiper operates in one smooth slow swoop on low and one smooth moderate swoop on high. It also squirts wet solution if you twist it's knob too far. I suggest returning to dealer to see if there is any binding from the rubber seal around the base of the mechanical wiper arm.
