06 sr5 2wd towing power
rraabb11
will i have any problems at a boat slip (slippery incline) pulling a couple of jet skis or a 20' boat? i dont want the tires spinning and have to get towed out!
Should be fine on a normal ramp. There are always ramps that are too steep and when wet can cause problems. I've been on ramps that were wet in the winter time where I had to use 4wd to pull others up the ramp. If the ramp is decent you should not have a problem.
Bill3508
