Jeffrey_VB
Will any of the OEM stereos available in the '06 SR5 4WDs play MP3 CDs?
toto said:If you burn your own CD's as Audio CD's, then you have to use software other than Windows Media Player. Microsoft doesn't support the CD Text standard, so a CD created with WMP won't have the text information that the CD player is looking for. With other software, make sure you enable "CD Text" if necessary.
To burn your own CD's with MP3 files, just fill a plain old data disc with MP3 files. If you put them into folders, the radio will understand the folder structure. However, it does not understand playlists of any kind, so don't bother with that. With MP3 files, it gets the title, artist, etc., from the header in the MP3 file.
toto said:I've never used iTunes. I don't believe their standard format is MP3, is it? (I think it's AAC.) The Data CD option sounds like the way to go, but you may need to try the MP3 option if it has to convert the files to MP3 format first.
The Audio CD option should also work, although you'll get fewer songs per disc that way. MP3 is compressed considerably; that's the beauty of it.
toto said:I've been using Nero for CD burning.
If you have a bunch of MP3 files and Windows XP, then you can also use the built-in CD writing function in Windows. Windows data CD's work fine - the only problem with Microsoft is WMP and the CD Text on an Audio CD.
Be sure to finalize the data CD (don't make it multi-session), and also use CD-R discs. I don't know if a CD-RW will cause problems or not.
toto said:Sounds like you might have a hardware problem with the CD burner. The WinXP CD wizard should work. Drag files onto the CD drive, and then right-click the drive icon and "Write files to disc", and follow the wizard. Yes, it will put 700 MB of files on one CD, making the data mode much nicer than Audio CD's.
With Nero, you can use the Nero Express wizard to burn a data disc. Add files to the disc, turn off multisession, and burn.
toto said:I thought about this a little bit, and then I finally noticed your sig - you've got a 2005. If you have an OEM stereo, it doesn't support MP3 files. That feature was new for 2006.
You'll have to stick with Audio CD's only, but Nero should be able to handle that for you. Use the wizard to make a Music - Audio CD; add tracks to it, and then on the last page you can give the disc an overall title and artist. It will automatically pull the track titles and artists from the MP3 file tags.
