07 Alternator advice
Last night the battery light came on. After testing at the battery while running i am only getting 12V. After watching youtube looks like a easy swap out. Anyone have advice on a good inexpensive replacement? Also any additional tips i should be aware of?
Thanks in advance.
I picked up a reman alternator from Advance Auto parts a couple years ago and its been working great. I found a coupon online so I got 20% off
Had my mechanic do mine it was not a small job
Had my alternator replaced on my 06/ 07 last year looked like a straight forward job but my guy ended up having to disconnect the AC system which required draining and filling in order to get the old one out.
Sorry but you got taken. The alternator in the V6 and V8 can be taken out and re-installed without removing the A/C line and a recharge.
From the manual, V6.
Pretty straight forward swap, at least on a v6. I went with a low mileage used OEM unit. These seem to last longer than a rebuilt from your local parts guys.
I bought a used unit from a dismantled 4runner. $65 worked like a charm. OEM is always better than aftermarket or rebuilt.
I went with one of these units: 200 AMP 13983 Alternator Lexus LX470 Toyota 4Runner High Output Performance HD | eBay
Haven't had it long enough to speak to longevity, but the customer service from the company was great. Just be warned if you pop up to the 250A unit you will need to replace the end of your charging wire, and should probably consider a big three upgrade.
Followed a similar route: went 240a and did the big 3 upgrade. Had it for over a year, works well.
Seymore,
Thought I had grabbed the correct one. Here is the V6, still no A/C removal.
2001ATL
