07 fj lift work on 4runner?
OME lift will cost you $744 and OME is a very good suspension lift kit. It gives you 3" and for the price of $744 it is a good deal.
hey PanamaRed, check out my post on the 5.5inch lift kit for the 4th gen i just used 2 different spacer kits. i got a total of 5.5 inches in the front and 3 in the back. looks o.k. front is one inch higher than the back. and i didn't spend 1600.00. probably 400.00. check it out and let me know what you think.
2 spacer kits...? What type of shocks have you used? With more then 4" you'll be killing your CV angles.
not just the CVs, gonna break the balljoints on the control arm plus the coils are under tons of stress, they are under stress with one spacer, putting two spacers is crazy
2007 fj cruiser pro comp lift
Yes, it will work, but this kit will require cutting a cross-member, so your warranty will be void. I'd wait till warranty will expire and then do the upgrade. My 2c.
Do you know if the 3 inch pro comp lift for a 2007 fj will fit a 2005 4 runner
