07 limited navigation question
DR.2B
does anyone have any information on overiding the nav so you can enter directions while the car is in motion. currently my truck needs to be at a stop to change the destination. thanks
If you do a search for "override" you should be able to find a lot of threads for the steps involved to make it happen. Good luck!
i tried those "tricks" found in the forum and online to bypass/override that function, but those tricks seem only working for 03-05. sorry, i still need to do a fully stop to punch in destination like you.
There are two ways you can do this.
Cut the vehicle speed sensor (VSS) wire and install a switch. The other way would be making a hybrid disc, using the loading.kwi file from an '06 disc.
