08 V8 4x4 - El Camaleon Azul
The gas cap that was on your truck when I bought it was not OEM and it had the same issue. Replaced it with OEM right at 2 years ago. You would think it would last longer than that. :noidea:
Yeah, I knew it was a Toyota cap, thought it was original though based on how firm the seal was. 2 years is a bit short on lifespan.
I put a thin coat of Silglyde on the new caps gasket to try to keep it pliable, would think gas is gonna take it right off though.
Uhhhh, these aren't gonna fit?
Seem to b ok going straight on flat ground.
Need to make some room!
IMG_3580_zpszaqvh1ty.jpg~original
IMG_3578_zpsrd5csegw.jpg~original
IMG_3577_zpsw5wlcoik.jpg~original
Getting a lil hand! Accessing parts is sometimes best left in the hands of the pros in the know. Or who they know
Glassworks Unlimited
Best product, hard service. If you want a set and don't want to ride on a washing machine for months, find a shop that has an amazing relationship with them
DMZ fabrication, Jeff, is one of those places. DMZ got it done and quick. http://dmzfab.com
Had Jeff instal them as well, for that perfect fit
Now I just need a bumper and some paint to get a more useable space that looks and works amazing.
Baby steps it seems
image3_zps35qurzhy.jpg~original
B01CFD23-C912-401E-A662-42F907350F13_zpsqu5xoxjd.jpg~original
been busy stripping down and prepping!
nasty Missouri salty roads have gotten in. So the cleanup, which i will add is NO FUN, has begun to cleanup the frame
step 1- expose it
step 2- wire wheel and sanding wheel grind it, remove as much rust as i can manually
step 3- treat the cleaned frame with Duplicolor Rust Convertor coat https://www.jbtoolsales.com/duplicolor-sp229-vht-paint-rust-converter-11-oz/
step 4- quick prime coat
step 5- topcoat in gloss black with POR15 TopCoat and Eastwood Extreme Chassis Black Extreme Chassis Black® High Gloss 14 oz. Aero - Best Chassis Black formulation Available with Eastwood
heres the nasty. my ocd cannot handle this stuff!!
IMG_3901_zpsxvgijyzm.jpg~original
IMG_3910_zpsc8gncdoy.jpg~original
IMG_3913_zps2oteotte.jpg~original
IMG_3903_zpssdzwep94.jpg~original
IMG_3909_zpsykwmm2lu.jpg~original
also prepped some for the suspension. picked up some TC Cam Gussets. One of the oem gussets is already blown out and needs to be replaced, might as well beef it up
IMG_3878_zpsuwef5ceo.jpg~original
tabs tacked on the backside
IMG_3914_zpsmxzvxd0x.jpg~original
and fully burned in. PS- I'm no pro welder, but nothing has ever fallen apart! YET
IMG_3916_zps7jd7itfy.jpg~original
now, LCA's come off, then i gotta knock off the old ones and burn these on. All in good time.
Upgrading the brakes at the same time. Fronts were already upgraded to 5th gen calipers when i got the runner, but no treatment was applied so they are covered in surface rust.
Heres the rear 5th gen calipers. Picked up a set of loaded calipers from Centric.
Now ill remove the rust from the fronts and paint all 4 all purdy.
IMG_3879_zpslxcvpnxz.jpg~original
anyone looking to pull some rust. THIS stuff is amazing. Evaporust!!
https://www.amazon.com/dp/B00M0TLQ6..._m=ATVPDKIKX0DER&pf_rd_r=W67973X1RRACGFYESN2S
been using it for a couple years, it WORKS. soak your part for a day, wash it off with water, done. Paint. You even can reuse the stuff forever, just pour it back into the bottle till you need it again.
after shots coming :)
The goodies Ive been using to cleanup/treat the rust
image_zpsaxakcthi.jpeg~original
Here's what's going in my calipers. Akebono pads, after plenty of research I think these are best for a multi use runner
image_zpsexgfrrp8.jpeg~original
ss
Pics of the frame after wire wheeling and flap disking the hell outta it using an angle grinder, wipe down with etoh, and a couple coats of the vht rust inhibitor
image_zpsw9dqeuxl.jpeg~original
image_zpsivwvaoy6.jpeg~original
image_zpsydhe4a3b.jpeg~original
image_zpsztzzzvet.jpeg~original
image_zpsynjj92km.jpeg~original
image_zpskvtneh6s.jpeg~original
image_zpsl3eb5vme.jpeg~original
Came out very clean so far
Great thread with lots of good info! Can't wait to watch the build progress.
Thanks, thats the whole idea as far as I'm concerned! Share the experience and pass on info on what we find, and how things work.
Hopefully it is entertaining and provides some info that will save time and $$ when its your turn.
Always cool when there is some participation too- feedback, advice, or some good ole fashion jousting :frisky: Cant take this stuff too seriously
Been getting pissed at the rear hatch not lifting all the way, sat about 6" low and was bumping my head on it or having to lift it by hand! Ugh!! Even annoying when its sitting in my driveway on jack stands.
Saw the solution on another build here, thanks [MENTION=58450]tmcintosh3[/MENTION]
Armstrong hatch lift struts #6107 bought em off Amazon. Perfect fit, simple install. I thought i was going to have to play with the little ball/clip joint, but these even came with brackets for both ends. SIMPLE does not get any simpler.
Lifts quicker and to the top, time will tell if it stands the test
IMG_4003_zpscewjob9m.jpg~original
IMG_4004_zpsjoj7scma.jpg~original
reused the gasket on the doorframe
IMG_4009_zpsn9jdknez.jpg~original
IMG_4006_zpsfjwwawb8.jpg~original
STOKED!
Cleaned up the frame rust and got a good coat of primer and top coat paint on the frame and rear axle.
In the process of reassembly. Taking it slow and cleaning it up as i go.
Rear is first.
Heres the cleanup:
DSC_1992_zpsobmhbjlg.jpg~original
DSC_2001_zpszgpmxuuv.jpg~original
slipped a set of daystar bumps i had laying around, much better shape than the clapped out OEMS that were on it. These were made for the 1st ten runners running leafs, but fit perfect.
DSC_1997_zpsu5trynhq.jpg~original
one particular nasty rusted out area, cleaned it up best i could, but still was covered. Rust Converter did its job
DSC_1993_zpsfji21kyq.jpg~original
clean n free of da nasty
DSC_1994_zpssfztrfng.jpg~original
DSC_2000_zpsfky0rjvu.jpg~original
DSC_2004_zpsmzr0oqns.jpg~original
welded in a set of TrailWorxFab HD Upper rear control arm brackets, made for the FJ but fit just fine. i trimmed them up a bit since I'm welding them in.
Bomber, should hold up to some abuse.
DSC_2002_zpsp4ykv3d8.jpg~original
DSC_1998_zps7pljoafj.jpg~original
Diff. breather raised up out of harms way, mostly :)
Crown Performance brakelines all around. SS and extended where needed
DSC_1995_zpsyqladatw.jpg~original
Diagrams of brake line routing and Parking brake assembly, if needed for reference :)
user109510_pic34285_1436828697_zpsvkuqyjp1.jpg~original
user84265_pic35278_1440724264_zps90lianwy.jpg~original
should have the rear back together tomorrow, if kids, puppies, or other responsibilities don't get in the way!!
Picked up a set of replacement Prothane rear swaybar bushings.
https://smile.amazon.com/gp/product/B00387ZSXG/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
Found them posted in another thread where it was believed to be a direct swap using the stock brackets and these bushings, 21mm hole.
They are not. ;(
different width and diameter. Hole matches, but thats it. They do sell a kit with a new bracket too, not sure if that fits or not, next time.
IMG_4042_zpsnizaii8a.jpg~original
IMG_4043_zpsv772jjs0.jpg~original
was able to mash them in there anyway. Figure for the $12 i paid, i could mash them in, see if they work. Likely they will tear themselves up and get spit out. Whatever. Can always slip the old rubber POS back in.
IMG_4044_zps0z1urj31.jpg~original
Installed the rear ATL rotors, 4th gen.
https://smile.amazon.com/gp/product/B017VGUYR4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
5th gen Centric Calipers from Rockauto, coated with the Duplicator caliper paint.
Akebono ceramic pads
https://smile.amazon.com/gp/product/B000EQ0O7O/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Applied mandatory copper anti-seize to the hub to prevent a rotor frozen on later. Adjusted the parking brakes back to function, and hooked up the brakelines.
still need to get the front done before i can bleed the lines.
Looks nice, hope it stops :)
IMG_4038_zpsyeigyemn.jpg~original
DSC_2009_zpsbhmxje0v.jpg~original
DSC_2020_zpsowq0gr1l.jpg~original
This entire thread is full of win. Nice work Z... seriouly nice work. This build is slowing killing my wallet.
Sent from my Nexus 5X using Tapatalk
with the brakes reassembled, i spent the rest of the day attaching control arms and slipping in the springs.
ICON LCAs, Front Range Off Road UCAs and PanHard, Toytec RCC2.0HD springs, ICON 2.5 RR shocks.
DSC_2014_zpsc4cetjzf.jpg~original
Hacked off the resonator for a side exit exhaust. May slip a tip on later depending.
The exhaust will need some type of bracing near the end as well, don't let anyone tell you otherwise. As it sits it has quite a bit of bounce to it and will strike the frame with any serious fun going on.
DSC_2013_zpszbghhvlz.jpg~original
DSC_2006_zpsgu9bn3qb.jpg~original
DSC_2021_zpsbdhtsw6p.jpg~original
Adjustable swaybar links by [MENTION=98153]MStudt[/MENTION] on T4R- sharp!
DSC_2012_zpsr4xzp0ni.jpg~original
still need to bleed the brakes and solidly mount the shock reservoirs
Also picked up an RCI steel gas tank skid on a group buy deal. Nice big beefy plate of steel, install went very smooth as a one man job.
DSC_2018_zpsgfvgeegv.jpg~original
DSC_2015_zpstpw5z3j3.jpg~original
DSC_2023_zpsupetar1o.jpg~original
Slipped on the rear tires one dropped her on the ground so i feel like its getting closer to driving again :)
Need some rear mudflap mod ideas!
DSC_2028_zpscgezaky0.jpg~original
DSC_2025_zpscrf2bbde.jpg~original
DSC_2026_zpshhgbldai.jpg~original
DSC_2027_zpsimcmgpku.jpg~original
now to dig into that front!!
Frozen/rust bonded LCA cam bolts!
One so frozen the LCA bushing barely even flexed. Had to cut the bolts to pull the arm
Anyone have opinions on aftermarket vs OEM Toy replacements? Im leaning OEM
OEM, or shell out the money for the Total Chaos. Be sure to grease the cam bolts on the new one to prevent from happening again.
Sent from my XT1575 using Tapatalk
just to be clear, I'm not replacing the LCA- YET! this is just the cam bolts in need.
and thanks for the lube suggestions. Im a huge fan of Copper Antiseize on all bolts and bushings, then in wet enviro or low/exposed parts adding marine RedLine bearing grease
Do you have a link to either? Would love to try it out
H.Sikina
