1.25" spidertrax with aftermarket wheel?
schmiks
Hey guys, I've looked around and gathered as much information as I could have on this subject but none seemed to be the exact same as what I'm looking into. I currently am running 1.25" Spidertrax spacers on my '96 Limited 4runner (With fender flares)
I also am looking into buying Ion Alloy wheels with the specs listed below:
Lug metric: 6-139.7 (6 by 5.5)
Offset: -5mm
Center bore: 108mm
Load rating: 2500lbs
Backspacing: 4.3031 ( if i did the math correctly )
My question is how much further will this push my tire out? I am okay with a wider stance I was just wondering how much further this backspacing would push my tire out with my spidertrax spacers still being on?
Thanks for the help!
Stock is 4.75mm backspacing so with a -5mm offset which is 9.75mm less than stock. So your tires will be pushed out .38 inches more.
The change in backspacing will push them out the mentioned .3", but keep in mind they are also wider wheels (8" vs 7") so that will cause them to stick out wider too.
I gave spidertrax 1.25" spacers with land cruiser wheels that are 8" wide with 4.5" backspacing. This will be very close to what you will end up with:
My rear bumper is the width of limited flares so you can see your tires will stick out just slightly past the flares. It will look good!
Thanks for the info man! I am totally cool with that, just wanted to know how far they would stick out and your picture does my question justice!
seltzernator
