1" Body Lift
hulk311
What are the cons of a 1 inch body lift? I'm running a 3" lift and 33" tires and would like another inch of lift. How is the ride with the 1" body lift?
The only con is that it may not give you the sufficient lift desired. If you are already running 33'son I presume a 3" suspension lift with no rubbing, then you are doing good already. The pros is that the 1" body lift requires less work and adjustments as the 2" and higher, which makes it also cheaper.
