1" rear spacers?
Mudeprived
I can't seem to find any 1" rear coil spacers. All I see are 1.5" or taller. I have cargo in the rear and it makes my 99 dip a bit lower than the front.
I don't want a lift kit or lift coils, just a simple 1" lift to level it with the permanent cargo. Any out there?
I too was unable to find anything for the third gen that was under 1.5". I bought the daystar 1.5" and had a machinist turn them down to 3/4". Hope this helps!
I have a pair of helper bags that goes inside the coil springs, let me know if you are interested.
I got spaces for front springs on a land cruiser 80 from Australia. (Via Ebay)
as people put LC80 front springs on the back of ours I'd figured they would fit.
They did!
there seems to be a lot more choice in height too, in 1/4" intervals.
They did!
I'm trying to stick to toyota 4runner specific springs. I don't mind a lift spring as long as the spring rate is close to stock and it nets an inch but I don't think there's anything out there for my 99.
He's talking lift spacers. Top plate spacers that fit the front of 80 series landcruisers will fit the stock 4runner rear coils perfectly, and they are readily available in more sizes than 1.5".
I started with daystars but pulled them out and went with OME 890 springs in the rear and 1" spacers in the front to level the truck out. Works a charm.
Spacing out sagging springs never works out well because the spring is still worn out.
I also put in new rear NGTR-4R shocks and a longer rear brake hose. Got everything from Chris at Toytec.
Reviving an old thread
I’m currently running Daystar 1” Front / 1.5 Rear on moog coils.
Installed in 2013 Looked great up until last year 3/8 rear sag present on half tank.
Anyway I’m thinking about going with 809s.
How did they work out for you , did they sit fairly level with 1” front spacer.?
Phil-
Whiteline makes something you may be interested in:
30mm (1.1"): Whiteline W73404
20mm (.78"): Whiteline W73420
I'm running the 20mm units above with OME 906 rear springs. I opted for this over stacking 2 10mm trim packers on top of each other.
EDIT: OH geez.. I see this thread is from 2017
Thank you [MENTION=279370]WeakSauz[/MENTION] the 20mm whiteline might be just what I'm looking for. Just put on 906's and looking for a little more rake.
seltzernator
