FS 2005 4th gen V6 SR5 4WD with upgrades, $17k, West Richland, WA
sharpie223
Junior Member
Turn-key 2005 SR5 V6 4runner ready for off-road use while balancing comfortable daily driving. Always well maintained with high quality fluids. Excellent mechanical condition, no leaks, doesn't burn a drop of oil, and shifts smoother than any other auto trans I've driven. Painted with UreChem Beryllium Orange Metallic and glamour clear, this color absolutely glows! About 180k on the odo. Asking $17k, shoot me a PM.
List of upgrades:
-big brakes upgrade from a GX470/4runner sport
-Bilstein 5100 shocks all around
-moog lift coils
-~3" suspension lift between coils and shock adjustment up front and coils and spacer in the back
-1/2" body lift
-steel, frame mounted, rock sliders
-poly performance front UCAs for proper camber/caster
-adjustable rear lower control arms for proper pinion angle
-heavy duty sway bars
-polyurethane suspension bushings
-Dr. KDSS panhard correction bracket
-ECGS front differential bushing
-frame has been painted with high quality MCU for lifetime corrosion protection
-URD exhaust cam gears
-URD equal length headers
-manifold spacer of similar design to the dyno proven XTP spacer
-Tuned by OTT. VFtuner and tune files included
-265/70r17 AT tires (wildpeaks)
-comes with winter tires that should still be good for a season, mounted on their own rims
-battery upgraded to AGM with proper charging circuit
-side exit exhaust (no fume recirculation when all windows are down)
-touch screen head unit
-cargo area drawer system that can also expand into a full length sleeping platform
Sure, is there a particular part you're looking for or general? Might sound like a dumb question but I'm not in an area of the country where frame rust is an issue.
You do you, I'm not interested in buying, just giving you some advice, just because you're not in an area known for rust these, T4Rs frames are known for rust and anyone knowledgeable in these T4Rs and interested is for sure going to want to see the frame, as much as you can to show it not rusted.
Good luck with the sale, especially if you don't include photos of the frame!
jesslstn854
