100,000 mile service
riceandpho
Elite Member
hey guys, my truck has about 102,700 miles so far, what do i need to do now? my spark plugs are fine since i changed to iridiums at 40k.
now i need to change the coolant right? also the uper and lower hose and the belt right? i found some hose and belts off summit racing, its dayco , autozone have that stuff too, if i order through summit i spend about 60 compare to autozone at 75. should i just use toyota oem stuff?
Coolant, diffs/transfer case, brake flush, transmission (depending on how you feel about it). If you have the V8 then timing belt and water pump.
