10a fuse burns out with HID's. Question...
"Recently I insalled xenon depot's xtreme HID kit for the 4runner. (low beam)
I didn't hook them up to the battery.
my 10a fuse keeps burning out and one or BOTH lights stop working...."
Hi alext72888,
My 'OPT-7' HID kit is designed to plug right into the factory low-beam female sockets (no additional wiring kit needed)! Yours should too! If you're referring to the factory '10A fuse' for the factory low-beams that keeps blowing, then there's a problem with the ballast/HID Bulbs!
Send the kit back for a refund or an exchange to replace the faulty equipment. If you need a kit that's inexpensive and flawless in operation, here's one you can depend on (about 30 minutes to install) and have been in for a couple of years now, have NEVER blown a factory fuse and trouble free:
Just $28 bucks: OPT7 Slim H11 HID Kit Headlight Conversion Bulbs | All Xenon Light Colors | eBay 'Best to you',
rig
different problem for me...
xenon depot 5k HID kit with canbus and hooked up with relay directly to battery. Yesterday I parked my car and a few hours later I noticed just the passenger highlight was ON. Car off, lights in 'off' switch in side cab, yet the headlight was just ON. I tired everything Drove it awhile, messed with on/off/auto/fogs etc. and finally just unplugged the wire. Now the light won't turn back on :confused: Iv'e run this kit for 16 months with 0 issues. Haven't had time to reassess but ill check the fuse...
[MENTION=12905]XenonDepot[/MENTION]
Sounds like you had a relay that failed and stayed closed.
Both my Xenon depot's xtreme HID fuses blew this week,
The XD kit was bought on black friday and installed after christmas. ( approx 7 weeks running)
35W kit
I just noticed that the 4 people having this problem have all bought the kit within the last 3 months..... Bad batch?
[MENTION=124560]alext72888[/MENTION]
[MENTION=129950]scotty0196[/MENTION]
[MENTION=150019]Blubayou[/MENTION]
snapple13
Thanks for the post - re both of the fuses, are they the ones in the relay harnesses we provide, or the truck's fuse box?
It's not really so much a matter of quality here, but the amperage required of the ballasts to ignite. We could reduce that number considerably, but it would take ages for the ballast to warm the bulb up to its full operating intensity.
No doubt that Opt7 kit would probably plug n play with the factory wiring, while thats convenient, the AMP draw is so low (and directly correlates) with their ability to bring the bulbs up to intensity.
That said, we really recommend running the provided relay harnesses with the kit. Since they'll draw power directly from the battery and only relay on the factory wiring for the on/off signal, it will be an easier load to handle on that wiring, so the fuse wont blow.
First time on this forum;
I’m trying to figure out an issue with the rr htr fuse 10a which keeps blowing out the second I install a new fuse, I don’t have anything plugged into the cigarette port, I don’t have any special lightbulbs or anything... all other fuses are working properly, the only thing is that my door ajar dash warning light stays on although I changed all the door panel switches except the tailgate, idk if this is connected but the fuse is for rear AC
I see no mention of resistance and or voltage checks performed before or after these kits were installed. Resistance checks should be performed before power is applied followed voltage checks. Does this kit come with a wiring diagram, expected values for said checks and procedures for troubleshooting? If not, I feel there should be - because there could be an existing problem now complicated by installing new equipment; or issues with new parts. There should also be values included for checks made to new parts before installation (in case one is bad or out of spec).
There are countless threads about the install of new electrical devices and the problems that result in people asking for help. Do the manufacturers of these items just expect them to work without knowing how knowledgable the person installing their products is?
If you are blowing a 10A fuse obviously something is wrong. Substituting a larger fuse is a bad and unsafe idea.
delislerebecca
