115V AC power outlet retrofit?
rubberducky
...does anyone know if one is available from Toyota? I installed my Scion head unit today, and it appears as though the wiring is already there. I'd need just the dash switch and the outlet itself (I think anyway).
Not sure, but I can tell you that the inverter itself is located in the rear cargo area, behind the lower driver's side lower panel. If you need to remove that panel, do a search on my name to find the instructions :)
So your saying we already have an inverter , and just need to write it up? Sweet, I know what I am doing this weekend then.:D
Do a search. This was discussed before and I think the outcome was that it would be VERY expensive to add the 115 outlet by Toyota. BTW the inverter is not there unless you have the 115 outlet as original equipment.
I got a 400w 3.8a inverter from Home Depot for $40. Works really well and has an active fan.
No, I'm not saying you already have an inverter. I'm saying that if you *do* have one, that would be where it would be located.
-Frank-
