115V AC pre-wired?
hksjza70
I've got an '07 SE, I'd like to add the 115V adapter in the console, anybody happen to know if this is a pre-wired item?
(So all I'd have to do is add the plug in the console and button on the dash)
I ASSUME this would be a pre-wired item just based on the cost. (less than $100 option)
You also need the inverter and a relay plus some wiring.
Sorry, should have been more specific, I 'd like to add the factory option 115V.
Is the previous post in reference to this as well or only to aftermarket versions?
If you didn't get the 115V with the car then you don't have the 12V to 115V inverter mounted behind the plastic trim over the drivers side rear wheel. You are also in need of the relay in the relay box behind the drivers kick panel there is no wiring to the console where you want to add the plug, and no this is not about aftermarket stuff.
