12V Power
pmdata
I've got a new three point, 12V power kit that I would like to hard wire off the fuse box. I'd like to have it switched (ignition on), but it has a switch of it's own that I can turn off.
What's the best way to wire the unit? I know where I want to put it, just not where to run the positive off of. Directly off the fuse box? If so, how do I add the wire into the socket.
I'd rather not spice any wires, but I'm willing to wire it into the existing power point.
I've done a good search, I just can't find any specifics.
Thanks for the help.
If I understand you correct, you could use one of these....
$7.99 from Radioshack. The black square cover comes off.
You'll have to crimp a connector onto the power wire in order to tap onto the mini fuse. You'll have to get a "O ring" connector to tap onto the ground in your car.
You can tap into the fuse box using "mini fuse taps" $1.99
Just make sure to tap into a fuse that will provide you enough power to power your device. If you want the power to turn off when your car is off, then choose a fuse that isn't still "hot" while the car is off. Always make sure to use fuses.
Make sense? I hope that's what you were looking for....
:D
Perfect. Thanks.
I have the power point, now I just need a fuse tap and a location on the box on a 4th gen that gives me enough power to run it, on when the truck is running.
I'll take a look at the fuse box in the manual and I should be good to go.
Thanks again.
Pete
Pete,
Glad I could help.
If you have power seats, that fuse is always hot. I have a 2wd t4r and I tapped into a "4wd" fuse that only comes on when the car is on. Pretty easy to do.
I did however scratch my head why I had a "4wd" fuse in a "2wd" t4r....
-Rob
Good stuff, thanks again.
Any open spots on the box that have switched power for 12V?
Don't ever pull that 4WD fuse, knows what could happen... :D
Hmmm....The only switched fuse that I've used is the "4wd" one on my 2wd.
I don't remember if you can tap into something like the moon roof or maybe the rear wiper blade. I would try to tap into something that you don't use as often so that you don't run the chance of overloading the fuse.
