D danjko888 New member Sep 6, 2008 #1 i found some rockcrawler wheels that are 16x8 with a 5" b.s. would these be a problem if i want to run 285's??
lowmans1966 New member Sep 6, 2008 #2 most likely unless you run a spacer. with 16x8 and 4.5 bs wheels running 295/75/16 tires I rub the frame a little at full lock. you, with a half inch more backspacing, will probably be worse off.
