Sloan said:i want to run 265/75/16 but if his 99 is rubbing then now i'm scared to
Ron Helmuth said:thanks greedy the engineers here that I work with agree that a lift would expose a smaller area of tire cross section to the fender that it could rub against-that is a big help in visualizing how that would look/work out.
And generally speaking I am hearing most folks say stay away from the puck or spacer lifts, and to go with taller springs and or shocks is that generally correct?
roc doc sorry again to be hijacking your 17" thread
Greedy said:Yep - if money isn't an issue, new front and back colis and shocks are the way to go. Better, firmer ride, better handling and increased height all at the same time. Check out sonoran steel's web site. He has numerous lift options an good explanations for what's included and the type or ride they will produce.
http://www.sonoransteel.com/store_complete_liftkits.html
p nut said:I think since we've rocdoc's issue, we can safely hijack this thread...actually, not a hijack, but more like a bus transfer.
I've also looked into doing a lift. The Soronan 7.1 system would be ideal. I've also been looking into the OME lifts found here:
http://www.rocky-road.com/4runner.html
They don't really say what the difference is between Medium and Heavy Duty.
Trying to decide if the extra cash is worth it for the Soronan lift.
Ron H - Photobucket is REALLY easy. If you've already signed up, just upload the photos. After you do, you will see an "IMG" tag. All you have to do is copy that (which is done automatically when you click on it) and paste it on your post. Simple as that. :bigok:
Greedy said:I actually have an OME Lift - 882's in front and 901's in back (i think). I the the medium duty shocks and they are plenty stiff off road and still have good road manners.
