No your thinking of the 17" rims. I have the same wheels that are in your signature of your 4r limited.I thought they were just clear-coated?
Aren't they just polished and then cleared?
You're really worried about that? In the next year, your wheels will end up more damaged, scratched, curbed, and faded than you would like. And that's IF you're able to fix that wheel to where it would look new (you probably can't). It's not that I don't have faith, it's that wheel work is super tricky, and results are far from guaranteed. It's usually only easiest to have even results when you do all 4. If I were you, I'd make your brother buy you a six-pack of brewski's, and forget that ever happened. Maybe put it on the back passenger side so you don't see it very much.
I like my stuff perfect and take care of my wheels. I bought them new 2 years ago, and up until he took them they had no damage anywhere . He ended up screwing up all 4 rims because the machine at his work is crap. Two of them have a minor scratch (which I can live with), but the other two have nicks like the above pic. It happened while breaking the bead of the old tires apparently and figured out why after he was all done. I'm gonna looking into finding a way to match or just repaint all the rims. I'd almost buy a new set.You're really worried about that? In the next year, your wheels will end up more damaged, scratched, curbed, and faded than you would like. And that's IF you're able to fix that wheel to where it would look new (you probably can't). It's not that I don't have faith, it's that wheel work is super tricky, and results are far from guaranteed. It's usually only easiest to have even results when you do all 4. If I were you, I'd make your brother buy you a six-pack of brewski's, and forget that ever happened. Maybe put it on the back passenger side so you don't see it very much.
