1988 4runner complete drivetrain newton nj 07860
88rnr
IMG_3381.jpg~original
22rerepowerreciept001.jpg~original
Drive train:
Runs but un-drive able due to front end damage, was driven to the accident though: 22re jasper rebuilt long block motor installed 9/11/12. 670 verifiable miles! Odometer reading and install receipts for proof (motor new from Jasper was $2600) . 5 speed, new clutch, throw out bearing newer input and output bearings in trans, t-case, rear drive shaft and rear end. I have run the motor for about an hour or so on jack stands taken it thru the gears, although due to the accident damage I will not put it in 4wd since front A-arm was hit. I have taken video to verify as motor will be pulled this week.
I prefer to sell entire driveline for $1500 (motor with all brackets, accessories and wiring attached (install and plug and go!), motor mounts, trans, transfer case, drive shaft, rear end and all hardware)
If I break up prices as follow:
Motor $1100, 5 speed trans, clutch $200, transfer case $200, drive shaft $50, rear end $100.
Master cylinder $25.
Brand new radiator/ used shroud $75 set
All under hood accessories also available, please inquire.
Components other than motor have 166,000 miles on them.
tobasko556
